Tuning Fiat palio 1.6 16v turbo
RSAFIATCPT
Cape town
Hey guys I'm busy with my fiat palio 1.6 16v motor and was wondering if the fiat uno turbo connecting rods is the same size as the palio 1.6 16v and if it would fit the palio crank as I'm busy with a turbo build and would like to order so rods
So what I got is the following
Gt 35 turbo
Standard pistons machined abit down for compression
Standard crank
Dictator management
550cc injectors
6bar fuel pump (4bar fuel regulated)
Downpipe
Thinking of only boosting it at 0.8bar
So I'm this far now with the build wish I could upload the videos but it will take too long I have a custom intake aswell I need to get a pair of standard OEM Uno turbo rods I have a set of wiseco pistons for a sr20 det 87mm that puts but only have 3 pistons so I'ma stick to the standard pistons
here's an update on what I got so far I have a set of cams now I'm selling the wesico pistons to buy a gt28 turbo I have the turbo branch and a blow off valve I will need a external water gate still
I decided to drop this motor into my Punto Evo 2011 as it's much nicer looking then the palio it has bigger brakes coilovers and also have stabilizing bars
The grearbox mounts are all the same as I checked so I will get me a Uno turbo gearbox
I will just get a customised engine mount
I will keep this update going I will be the 1st one I know I'm South Africa with a fiat Punto 1.6 16v turbo
I really like your ingenuity. Good luck with the build.
Thank you I'm getting some new parts by this weekend then after September IL start to build and assemble I have met 2 guys this side that's making 280kw and one guy making 411kw the guy I got the turbo parts from made 408kw and 648nm
