Technical Fiat Multipla ABS.
Black Shuck
Gt Yarmouth
Hi veryone, Im new here so go easy om me please!!!, I have a Multipla 2001 I.9 JTD, each time I turn the engine off, the ABS Warning light comes on with a Beep and the CU reads EBD Faulty Contact Garage. Does anyone have any Idea what this is? Cheers for the help!!
The ABS light goes out after 1-4 seconds, and the ABS system works when driving ?
Then there isn't enough juice in your battery when starting the car from cold.
The battery is most likely on its way out, also measure the DC voltage when the car is idle, should be 14 volts.
1. Try recharging the battery, see if the error message disappear.
2. Get the battery checked if bad replace it.
