Technical  Fiat Marea 1.6 16V - Indicator problems
ticklish
Fiat Marea 1.6 16V - R Reg
I have an intermittent problem with my indicators.
When I indicate, sometimes the indicators work - other times they don't, or they may flash to indicate only once.
I have checked the fuses which are all ok. The bulbs seem fine too.
Is there such a thing as a wiring diagram, since I don't know where to start looking for loose connections? And does anyone know where the Relay may be?
:bang: Any ideas please? Help!
The fault is in the breaker. Take off the steering column's lower cover and look for a blue cube. Take it out and prise its cover open. Now touch up all solder points with a soldergun. Should do the work.
Otherwise (if you don't feel like soldering) just replace the breaker.
