Technical  Fiat Freemont infotainment system problem
Markann
Hello everyone, I'm new to this forum and I have a problem. The infotainment system acts on its own quite often, after it does that I can't press anything on the screen until I slide my finger over it. It's so strange. Then it works for a while and then it starts acting up on its own again. There is another problem, the climate doesn't work how it's supposed to. If I set it on 25 degrees celsius it will still shoot cold air and not mix it up to make the temperature 25 in the car, the only way for it to have hot air is if I put the car on HIGH (which is after 31 degrees). Any help would be appreciated, thank you.
Hi.:)
Rare vehicle.
For climate info see PANDA section..
Common control flap issue ;)
The infotainment.. ICE section cover
BLUE AND ME. And other fiat systems.
What engine do you have?
Charlie
Thank you for the answer. I have a 2.0 TDI, 150 HP, manual transmission. I'll check the sections out!
