Hi everyone just joined as I've have a common issue as it sounds on my ducato 2002 pre facelift model not starting. It first started when it was taking a bit longer to start then normal then one day it just would not start. Things I have done already bleed fuel system mine does not have glow plugs replaced flame starter replaced cam sensor and replaced the battery all fuses are fine. It fires no problem at all it just won't start only way it will start is with a small spray of Aerostart. Have had it to several mechanics and they have no idea. So much appreciated if you guys can help. Fiat ducato 2.8 jtd 2002 love the van just a bit frustrated thanks guys and gals
