Technical  fiat ducato engine stalls when driving
Guppie80
Rolde
I’m having some trouble with my 1999 Fiat Ducato camper.
For the past few weeks, the engine sometimes keeps running for a bit after switching it off (dieseling). This usually happens after only driving a short distance.
About two weeks ago another issue started: the engine occasionally stalls while driving, but it can be restarted right away. This only happens at lower speeds (around 10–50 km/h).
Since last week it’s gotten worse — the engine now completely cuts out. After letting it sit for a short while it will start again. It mostly happens when the engine has been under heavy load, for example climbing a hill. After revving hard for about 45 minutes, it just dies.
The fuel filter has already been replaced, the diesel and the tank are clean.
At idle, the engine runs fine — even after two hours it doesn’t stall.
Any ideas what could be causing this?
You haven't mentioned which engine.
It is possible on older pre common rail engines for the fuel cut off valve on the injection pump to be sticking, although that is more likely to be not wanting to stop rather than dieing whilst driving
If you supplied the engine details, you may get more replies.
