Hii Friends, My Fiat Ducato 2011 has failed today..when I try to start up engine after long resting days, engine does not start immediately..I tried second time and I thing some cylinders fired-up but when I leave the ignition key engine stopped again(by the time starter motor cranking normally,no slow down or power loss)...I tried third time to start but there is no action on the starter motor..I've checked the battery cables and battery itself and found everything are OK..all the electrical devices working normally including head lights..there is even no click sound from starter motor side..I suspect from starter motor selenoid which does not connect battery + with starter motor main ..Is there any relay between ignition switch and starter motor selenoid line which controlled by ignition switch? Thank for all replies.
