Technical fiat croma 2.0ie turbo owner with dilema
fiatcromamk1
in a house beside a road!
I have recently bought a mk1 croma turbo and the sunroof, passenger window and rear windows don't work although the drivers window works fine. Does anyone know if this is a common fault or will this cause me loads of hassle in which case I will get rid of it! Thanks
I don't think it is a common problem. Have cheked your fuses jet?
The relays dry up after a while...
...easier to replace than find. :)
Yeah I have almost the same problem except that none of my windows works and my Heater/cooler dosen't work either. So if you find a solution that works post it here so I can test it out.
Yepp the relays did the trick. Thanks for the information Liquid Knight I just switched out one and everything started working again.
