Technical  Fiat bravo noise 1.6
2shae
In my car :)
Hello fellas. Back on fiat:) I bought Fiat Bravo 2009 1.6 multijet 105 hp. Problem i am having is that my car makes noise when accelerating hard from still. Let me explain. If i pull off hard i hear somekind of..more like metal noise from passenger side. Like the engine hits the chassis. I checked all the mounts and they are ok.
Also, when car is hot..i mean when it is running a bit..i hear clattery noise from that area too. So i have read a lot about crank pulley? Is it possible? Also car shakes on idle too..not to much but it is noticable. Dunno because JTD engine is rough..so maybe it is normal. But thing that confuses me is why this clattery noise is not coming on when car started. Any suggestions?
Hello and sorry for my English.
I have the same car with the same 1.6 105hp engine and apparently I have the same problem finally found a solution to your problem; was it finally the crank pulley?
check alternator's pulley, she have internal clutch to turn only in clockwise sense, you can start a few seconds engine without alternator belt and listen
