Technical 1.6 diesel multijet 2008
Redon
Albania
Hey guys can someone tell me where is location and is hart to repair ac compressor noise because i change all filters oil and new belt and still have that scratch noise i ask one mechanic but he said me i need to change new compressor and is expensive??
Model
Bravo multijet
Year
2008
Mileage
270000
Can you identify the position of aircon pump from this photo, basically bottom front of engine forward of the crankshaft pulley, it will have the two aircon pipes going to it.
Generally if noise changes when air con turned on or off that would confirm it.
Often the clutch in the pulley fails, squirting oil into the pulley clutch may help, but not always and often the whole pump has to be replaced , obviously the air gas needs to be collected and replaced when doing the job.
I assume air con is working as they can be noisy if empty of gas and lubricant, but by that time probably too badly damaged.
If you don't use air con and noise is coming from there, it may be possible to fit the shorter drive belt from a non aircon model and remove the aircon pump.
