Technical  Fiat bravo ISO wiring
Guzmanus
Hello
I just bought a head unit for my fiat (A Newsmy carpad, that runs android), and the standard wiring included does not work, it does not turn on.
I've checked with my potentiometer, and the Fiat's ISO wires that carry 12V do not match with the unit ones. I've been looking around and this is a common issue but most of the info I find is for other fiat models (Stilo), or most of the links are dead and I cannot see the correct pinout.
Could you show me a correct pinout or what should I do? It looks like i should wire the red cable with the yellow one but i want to be sure not to fry my head unit.
Thanks a lot for the help
fiat bravo doesn't have ACC wire. so you need to choose one of those:
1. buy a canbus adapter (+allow you to use the steering wheel control - if there is)
2. connect a wire between HU ACC's and ACC wire from the fuse box.
3. connect the ACC wire to the +12V wire. it will make the HU working untill you will turn it off. so you need to turn it on and off whenever you are get in and out of you'r car
