Fiat Bravo Double Din Sat Nav microphone help...
I have setup and installed a Sony double din Sat Nav unit in my 08 Bravo and the installation has gone fine so far however I am having problems with the microphone. I would love to somehow already use the microphone built into the car for the blue and me instead of running a wire through the right hand of the car. When removing the head unit there is no easy access at the back of the unit to the right of the car however there is a big hole on the left which I used to run the wires for the USB lead and Navigation module. I was wondering if anyone knew how to tap into the existing microphone. If I could find the right wire could I just splice the 1 at the back of the head unit into the existing one?
I am thinking that maybe the wire I need to find is plugged into the blue and me box in the glove box and not at the back of the head unit if it is possible...
W00t! Nevermind I managed to run the new microphone under the driver side around the center console where the gear stick is and up the other side of the unit :D
