Technical  Fiat Bravo - Climate Control Issues
NielsBravo
Good afternoon,
I am a Fiat Bravo 120 T-Jet driver from the netherlands. The last few days I am having problems with my Dual Climate Control.
The switch on the CC Panel is pressed to 'on'. The light of the switch is burning. But the AC is not turning on.
If my mechanic is bypassing the relay (which is the wsitch to turn on the AC compressor) in the enginebay, the AC system is turning on. And it will get cold in the car.
If we plug it in to a Bosch Diagnostic set, all the buttons on my AC Panel are gving a good indication of working. Except for the switch to turn on and of the AC (the button with the snowflake), the Diagnostic set is always saying: AC is off.....
Where can we take to look to fix this problem. We are almost thinking of replacing the panel.
We managed to find a secondhand AC-panel, just to try and find out if there is an issue with my current panel. And it turns out that the panel isn't working any more. So, this means a new AC Panel, which isn't that cheap.
