Technical Fiat Bravo 2007 1.4 t-jet 150 starter motor location
Car had problems starting took to garage and they said cable was loose to starter motor which fixed the issue. Same problem after 5 months so want to check if its plugged in correctly before taking it to the garage but can't find it
it's located on the back of the engine, underneath the intake manifold... you don't have access to it unless you work from underneath.
