Technical Fiat Bravo 1,6 Mjet ECO-nothing doing!
BATTO
backofbeyond
I have 3 Fiats, 2-1.3 Doblo vans, and a 2008 Bravo 1.6 Mjet ECO.
We left the Bravo at Southampton for a week, and when we returned it wouldn't start, got a jump start, but although the engine turned over it still wouldn't start as not all the ldash lights came on. Then suddenly they did and it started. BUT the speedo, wipers, indicators, radio, lights, heater, fuel, temp gauge etc did not work.
Engine ran fine, came down M3, M25, A41 for 2hrs (without all the above!) the airbag, handbrake and low fuel lights stayed on, got home, tried to start it, engine turned over like a dream but no luck.
I've checked and cleaned battery connections, fuses, ecu connections, no luck.
I suspect the ecu, has anyone got any ideas please?
Just to let you all know, the problem was caused by the chap that gave us a jumpstart he knocked one of the two 70Amp fuses that are on the positive battery terminal and broke the fuse inside.
Got a new fuse from the Fiat dealer (note: this is not part that shows up on the partslist, but they found one out back), bolted it on and all good.
Hope this may help someone in future.
