Technical Fiat Bravo 1.6 mjet 2008 cabin air flow stuck on windscreen.
gazcoombe
Fellow Fiat Owners,
Has anyone had the situation of being unable to direct warm or cold airflow through either the foot well vents or the dash board (middle) face vents? The blower fan is working well on all speed settings, temperature is fine and the pollen filter has been removed and replaced. So, it's not the filter causing this issue. When I depress any of the airflow buttons on the climate control to redirect the airflow, I hear no actuators/flaps moving. And the flow remains stubbornly on the windscreen. What d'ya think, any ideas?
I had a similar problem, turned out it was a couple of plastic clips in the actuators that are situated in the passenger foot well. They can be a bit of a nightmare to get to as you have to remove quite a bit of plastic to get to them.
I have the same problem exactly on my t-jet 1.4
Try to give us more accurate position of those ****ty plastics maybe pics...
