Fiat Brava 1.6 16v IAW49F Tuning
gesh
Hi!
This is my tuning project fiat brava 1.6 16v turbo.
car info:
Stock ecu: magneti mareli iaw49f.b9
Stock engine: 1.6 16v
Map sensor: 2.5 BAR, bosch from auti A6 3.0 TDI
Turbo: TD04L from subaru impreza 2.0 turbo.
Ijection system: injector from fiat coupe 2.0 16v turbo, bosch 385cc, fuel pump stock, pressure in rail is 3.5 bar.
Exhaust: 63mm.
Front intercooler 550 х 180 х 65 in mm., inputs 50mm., cooler pipe system 50mm.
I have problem with read/write ecu, now i remap ecu with willem programmer:
remove ecu chip from ecu, put in adapter on willem programmer, programming ecu chip, remove chip from adapter and put in ecu.
I dont know, how i can read/write ecu map with galletto or mpps chiptuning software.
Galleto return error, when i read ecu.
