I have had this modified 850 Saloon for 4 months or so now and have been improving the electrics and generally trying to make the car reliable enough to use to go to work. It has the 903cc sport engine fitted with the twin barrel 30 DIC carb, tubular exhaust, etc.
Starting and running is fine from cold (for an old car) but when it has been warm for 5 minutes, it starts to missfire. This happens quite gradually, but will end with me unable to get over 30 MPH and eventually I'll stall. Once stalled, the car will not restart again, no matter what I try. After 20 mins of waiting it will start and I can go through the process again. All this means I can only go about 2 miles from my house if I want to go home again in a timely fashion.
Clearly a temperature related issue, but what? I just rebuilt the carb, put new manifold gaskets on her, adjusted valve timing, ignition timing and have new spark plugs, leads, rotor, cap and even a "boyer bransdon" box to help give a more potent spark, which it does.
