Styling Fiat 500 Stud Pattern
At a guess, 5 studs and a 97mmPCD.
Studs are easy to tell, theyre the bits sticking out of the hub.
IIRC, 97mm is Fiat standard, so I rekon they wouldnt change it just for the 500
A wobbly means you can fit a 4x100mm PCD wheel. to the 4x98mm hub. I can't explain how they work, but having seen them 'in action' they do work...
