hi guys,
we have a 2008 1.4 Lounge (with dualshift box), with 36,000 on the clock. since buying it a year ago i've noticed it uses a lot of oil (1 litre per 1000 miles). this seems pretty excessive. any explanations/similar experiences?
cheers,
eamonn
Welcome to the FF Eamonn.
I would suggest putting in new oil and filter and as previously suggested checking for oil leaks.
The oil should be 5W40 ACEA C3 which isn't that easy to get but Halfords have this
Castrol oil discounted at the moment. If you can get a staff discount or trade discount car it will reduce the price even further.
I would get an oil filter off Fiat directly which will cost around €8. Another option is to get the
Selenia oil which you will have to pay extra for if you're getting a service done in your local Fiat garage.
Oil flush is not recommended to clean out your engine but I did use Mobile 1 0W40 for around 500-1000 miles as a cleansing oil and then put in the 5W40 ACEA C3. A better suggestion might be to use a right spec oil and preferable cheaper if you can get it -
Comma sell a turbo diesel one that is the ACEA C3 - Using the wrong ACEA spec oil can damage your CAT. Comma can be got in the Motor Factors - note that this does not have the Fiat spec approval of
Fiat 9.55535-S2 which is not important for a car out of warranty.
The idea of using 10W40 semi-synthetic seems a bit pointless on engine with only 36K. Thicker oil will impact bhp and mpg but I could see that it might be beneficial if the engine was worn. Also looking at the
ACEA C3 oils that are available I haven't seen a 10W40 that meets the C3 spec.
