If anyone could help it would be great..
I have a Fiat 500 pop 1.2 2009 and its doing my head in. I bought the car for a cheap £500 with a diagnostic report from Fiat themselves which said it needed a new ECU. I have bought and put on a new ECU, new fusebox and new ignition barrel and the car still does not crank.
I then thought maybe its the starter so fussed around for 3 days replacing the starter, got there in the end but only to realise that hasnt fixed the problem.
I also replaced the battery for a brand new one which hasnt done anything.
I then thought lets check the connections/wires. Traced the wires from the fusebox, they look fine not burnt.. Checked the wires on the battery and sanded them down.. Checked the cables from the starter and sanded them down too. Literally all there is is a click when turning the key to start position.
Where can I look now?
Thanks.
Thanks.
