Waterworks
Hi, I have a Fiat 500 manual 2013 Lounge model. There were a selection of lights not going off or flashing on the dash and the Bluetooth was not responding either.
When the garage connected it up to the diagnostics it came up with Bluetooth Module Ecu being at fault. Luckily I got a used replacement cheap online and it fixed 100%. It wasn’t the same model number of module and from a Punto rather than a Fiat 500 but worked perfectly.
Unfortunately the fault P130562 was also identified. “Self learning neutral position valve- Not plausible “ pinpointed it’s position on the gearshift inside the car dash. I bought a used one online and mechanic fitted it. It didn’t integrate with the systems automatically and had to run a full system scan to integrate.
Hopefully this helps someone and I’ve explained everything as best I can.
Best of Luck
Best of Luck
