General fiat 500 airbag ecu module problems
what lead do i need to put to the car for airbag ecu fiat 500 2008 model i have read with it being can that i need elm and the yellow adaptor lead then on ebay it tell you the red lead is for airbag ?anyone know please.
sorry for the mix up but is kline not for pre 2000 year and on the fiat multi scan it says elm lead and when i try to connect to lap top it asl for elm lead with yellow adaptor.
hi there i have one of them leads to but i have had no luck i there i will try agian in the morning this is the set i purchased so wil i put one off the coloured end leads with the kline one or just that one and would the airbag ecu show up on body computer sorry for being a pain but there some many different Reference,s on what to do and coloured leads. http://www.lonelec.co.uk/index.php?main_page=product_info&cPath=1_7&products_id=35Data
1.This cable can not work if your car uses a protocol/bussystem like VPW, PWM or CAN-bus.
2. Terminal K = Bus of communication
3. Terminal L = Ignition for waking up car computing system (ECU: Engine Control Unit)
4. Existed 3 different protocols with same OBD2 connector incl. ISO/KWP, VPW, PMW
5. This K/L Diagnostic interface & cables work on ISO/KWP (Key Word Protocol) launched after 1996 only.
6. Supported also ISO9141 protocol
7.The Cables may work with some versions of the Carsoft, but carsoft used a lot of different interfaces during the different versions and also had some custom interfaces.
From memory the coloured lead isn't needed, but if you've got it then use it as it shouldn't cause any issues. I can't remember the colour, I just use the one on the list with my cables.
When you use the K-Line cable you need to change the com port setting of something iirc.
On my notebook I have to use COM8 port for ELM, and what ever the other option is for K-line. Its this later bit which I suspect you may not be doing, as its not really mentioned anywhere iirc, I think it was just trial and error by myself.
Hi patony, did you sort out your problems because i am having similar problems with cables and interface. Can you let know how got on ? thanks.
