Sylvester22
I've got a few questions about my 2010 Bravo Sport 198 I've purchased not long ago.
1- The sunblind doesn't stay fixed, skips around 30-40° in middle, just where it supposed to cover the sunlight best, so either too low or too high. Passanger side does the same. Makes no sense. Any solution?
2- Pedal rubbers showing signs of wear, it's sport pedals, so metal+rubber. Where can I get replacement or part numbers maybe?
3- Driver side round water seal has some damage on it, does anyone know the part number?
4- Indicator sound occasionally goes away, the lights work on all sides, just doesn't beep for a while. Any info on that?
5- Previous owner had changed all oem springs to diesel ones, as the front had touched kurbs/speedbumps a lot.
When the car goes over speedbumps, I'd noticed it later as test drive was on flat roads, I can hear a noise from the front only, even at very low speed, it sounds like spring hitting something metal. What it could be?
Thanks for any info on these.
