General  Faulty milage display.
Kevin Begley
Can the milage display be replaced on my 2005 Scudo, or do I need to replace the whole dash display?
What's wrong with the mileage display? If it's not showing up on the dash, it's probably just the backlit bulb needing replacing which is an easy fix.
I'm well used to replacing those small capless bulbs. The problem is that 4 of the small led's aren't lighting up on one of the figures, so I can't read the milage correctly. It's not a major issue, I am wondering if I can buy a replacement display r do I have to buy a full set of clocks to remedy this problem?
Sorry can't help you there, I need to take my own dash apart & fix the bulbs so until I do that I won't know how the digital readout is set into the speedometer.
If you're living in Dublin & find that the dashboard needs to be reconditioned, there's a crowd in Rathcoole that does it http://goo.gl/ESTcqE but it'll probably work out cheaper getting them in a scrap-yard if all the taxi drivers haven't snapped them up.
These two youtube videos are good. One shows how to get the dash out and fix a bulb.
The other shows a dash repair centre guy fixing the pixel problem that you are experiencing. The latter looks a bit tricky.
I can't post links yet as I've just joined
If you google 'scudo odometer not working' and see what videos come up you should find them OK
