fao tom
fao tom
T
TAFI
if i was to replace the 6x9's. i would want to put in a pair of 8" speakers (not subs).
what ones would you use and were can i get them from.
thanks TAFI
What is your desired effect? My interpretation of your setup is that the 6x9's are there for boot open running rather than up front sound. Is this correct?
I don't think you really need an 8" as you have the 12" for bass.
Re: Re: fao tom
yep it is for boot opening running as i am giong to put a dvd in the boot lid next and have the sound going though the H-unit.
Re: Re: Re: fao tom
What you want is either some good 6.5" coaxials or better still some 6.5" components. You've got enough bass so what you need is clear mid and top which 6x9's have never really been able to do.
What freq are the 12's x-over'd at?
An 8" would be good (there are some REALLY nice but terrible expensive 8" mids) but then you'd really need a 4" mid as well and then you are getting into active territory and more amps.
What makes/models are your fronts?
Re: Re: Re: Re: fao tom
The Subs are crossed over at 40hz...
The fronts are Mac Audio dynamics 2x13's (70wrms), and also Magnats X-centrics 2x16's (120wrms).
TAFI
Re: Re: Re: Re: Re: Re: fao tom
yes the subs r in sealed boxs
Re: Re: Re: Re: Re: Re: Re: fao tom
You using an external active crossover or one in the amp?
Re: Re: Re: Re: Re: Re: Re: Re: Re: fao tom
If i'm reading the kicker page correctly, it says the low pass is between 60 & 120hz, but you said it was crossed over at 40hz ?
Isn't 40hz a little low Tom ?
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: fao tom
sorry i was wrong..(me bad)
tafi
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: fao tom
Sorry Tafi, may come across a little strong there, apologies
just went out and had a look, and it at 70Hz.
TAFI
That is a tad low, maybe if he was running 8"s for midbass as well.
I'd say 60-80Hz crossover. The 6.5"'s will be really struggling at volume.
what would you set it at Tom please. as i have it set at 70Hz
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: fao tom
70 is good :)
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: fao tom
By the way TAFI...we had a complaint from a guy 20 doors up...about the noise las night :)
Daz
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: fao tom
SORRY DAZ
Does that guy drive a white HGT? :)
S
5
489
sly si
S
A
2
382
M
A
1
171
M
S
2
265
sly si
S
K
1
365
M
