General Fan problem
General Fan problem
Dragos1990
Nuneaton
Good evening
I got a Fiat Ducato 2023 van and the problem is with my fan it’s working all day
When the water temperature gets 85 will start and work till I stop the van its this normal or I need to change any relay
Model
Ducato
Year
2023
Good evening
Do you have airconditioning in use? This will affect fan operation.
The fan relay is working as it should, as it turns the fan off when you switch the ignition off.
No I don’t use the air con
After I stop the engine the fan stop
So its normal to work almost all day
Hello @Dragos1990
Doesn’t sound normal if you’ve not got the Aircon running. Our local Evri delivery chap has a 72 plate and leaves it running whilst working and the fan isn’t constantly running
Amongst a myriad of issues, you could have ;
A faulty fan temp or coolant temp sensor.
A stuck thermostat ( should show as an over heat on the temp gauge).
Wiring fault or stuck relay.
An emerging problem with the coolant system such as a beginnings of a head gasket leak.
( could show as under heat or over heat no the temp gauge.
Is the ambient temp sensor reading correctly on the dash? - that can cause all manner of running issues…the list is endless
A check of any existing fault codes and live data is in order me thinks….
No any faults
And we’re is the relay position
And no overheating
And sometimes start on stage 2 of the fan
Can be a problem exterior temperature a problem?
And start stop don’t work
On vehicles without adblue no exterior temp signal = no dpf regeneration.
I do not know if lack of exterior temp signal affects adblue vehicles but it could.
Did your symptom start after the mirror change?
I buy the van from auction and was side damaged and I change the wing mirror I’m not sure if got this problem before or after I change the mirror
But start/stop don’t work because the fan works almost of the day
If I don’t drive after 5 minutes fan stop and get back after 10 minutes and on motorway same stops
