Ok.. Chip is out, we put new one inside, decided for TDA7386... Everything works fine, except, when power on by ignition, or radio button, there is a speaker pop noise like one that can be heard on older amps...
All TDA chips have standby and mute functions, so probably chip itself is malfunctioned..
Also, this chip is 4X40W, so for the same volume, output power is much bigger
I assume, that the original chip is actually TDA7385(4x30W version)
What do you think is causing pop noise when turning on???
