Extended warranties
Extended warranties
HornetUK
Established member
United Kingdom.
Is the warranty direct gold warranty worth taking out in year 3 or should I wait until year 4? Its only £20 per month.
Although when it says the following under suspension do they repace shocks for nothing when they go?
Anyone have an extended warranty?
With GOLD Cover all of the following parts are covered and we will pay the parts and labour costs if you have to have something replaced.Parts not specifically mentioned are not covered.
Engine
Cylinder head, internal bushings, oil pump, crankshaft and bearings, tappet gear, valves & guides (excluding burnt or pitted valves), pistons & rings, cylinder bores/liners, con rods, distributor drive, starter ring gear, flywheel, autodrive plate, camshaft drive belts, camshaft & cam followers, cylinder head gasket, cylinder block, crankshaft pulley, turbo/intercooler units, rear main seal, rocker assembly, push rods, timing gears, timing belts & chains.
Clutch
The master and slave cylinder, clutch cable and pedal assembly.
Transmission (Manual, Automatic and Overdrive)
Manual Transmission: gears, synchromesh hubs & rings, selectors, shafts, bearings, drive chains plus gearlever and bushes. Automatic Transmission: torque converters, brake bands, valve block, governor (manual & electric) oil pump and seals, drive chains, gears, input shaft oil seal, clutches, servos and modulator valve, bearings plus gearlever and bushes. Overdrive: Gears, shafts and bearings.
Front Wheel Drive Unit
Crown wheel and pinion, differential unit, bushes and bearings, plus external drive shafts, couplings, C.V. joints and rubber boots, hubs, drive flange and universal joints.
Rear Axle
Crown wheel and pinion, differential unit, shafts, bearings, C.V. joints and rubber boots, oil seal and rear hub, & drive flange.
Four Wheel Drive System
Front differential, inter-axle differential and lock, rear differential and lock, bearings and shafts, couplings, C.V. joints and rubber boots, hubs and drive flange.
Propshaft
Propshaft, universal joints, centre bearings and oil seals.
Suspension
Shock absorbers, upper and lower wishbones, bushes, springs, spheres, displacer units and wheel bearings, self levelling suspension unit, reservoir, pump and regulator valve.
