Technical expansion tank repair
sprie
rye
I have an issue with my overflow tank. The “nozzle” nearest the camera in the photo (the smallest) came away when I removed the hose. I have temporary stuck it back in.
I was going to buy a replacement tank, but apparently, they are no longer available, so I need to repair it.
When I started up the engine, water did soon leak from this joint, so it does need a reasonable repair.
My current plan is to get one of these:
https://rc.supplies/products/aluminium-threaded-radiator-overflow-stub?_pos=1&_sid=0598e6277&_ss=r
I am also getting the matching boss/ferule.
I was thinking I could wind the stub into the hole in the tank. I was hoping to use the boss on the inside, to use to tighten the joint, with a rubber o’ring to help seal.
But looking at the tank, the nozzle is a long way from the screw top, and there is also a baffle just inside the nozzle.
So, I am thinking:
  1. I rough up the exterior surface of the tank
  2. I screw the stub into the hole, with some good quality gasket sealant on the threads
  3. I put some JBWeld around the exterior, in the join between the tank and the stub.
Questions:
  1. Is there another/better approach?
  2. I am assuming it is a pressurized system, is that correct. If so, the best I can do is keep coolant in tank just on Minimum to avoid excess pressure.
The only other thought i had was to cut a hole in the top of the tank, so i get access and can use the boss on the inside to fix the stub strongly. But then i have got to find a way to seal the hole that can withstand the pressure.
So, I am thinking:
Questions:
When you compare the volume of coolant saved against total volume of cooling system, you are unlikely to reduce the pressure significantly. Also less reserve if a leak did occur. If possible plastic welding or a used part as suggested above would seem to be a better option.
