Someone was doing stainless ones on eBay for less that the Sportex ones. 4" is what my T5 has -- it'll look a bit silly on a stock Cento.
It's a sporting and its not going to be stock for much longer, also is there any difference in sound from the 3" compared to the 4"
Standard SPI mani and cat will work fine -- just weld on a boss for the post cat lambda.
Would a de-cat be an option? As in a mix and match with an spi manifold, join it to existing pipe? It may be a silly question but I don't know what the spi exhaust is like in regards to what parts of pipe there are![]()
Not if you want it to pass a MOT, damn sure they changed the rules so that 2001 on cars have to have the original (type) catalytic converters.What about the mani-cat? I have one and I'm assuming @Fishguy has one aswell, is getting a standard manifold an option?
Should be fine, but depends on the MOT inspector -damned expensive exercise if he makes you change it backMy guess is you'd get away with it most of the time.... I can't see a MOT man giving a damn.
Should be fine, but depends on the MOT inspector -damned expensive exercise if he makes you change it back.
Probably cheaper just to take it somewhere else!![]()
