- Joined
- Feb 16, 2005
- Messages
- 5,983
- Points
- 988
Its been high since the latest swap, but is really getting on my nerves now. I was planning on doing some work to fit cams etc, so will need to look into this.
Compression test values are all within tolerance, no smoke at idle, no visible smoke from drivers seat under load.
No leaks anywhere.
The only places i can imagine i need to check are the piston rings/pistons and the stem seals...are there other areas that i should keep an eye on?
Excessive is defined as probably 10L in the last 10-15K, about 3-4L in the last few thousand....its now below minimum again
Kristian
No leaks anywhere.
Kristian
