PuntoPerv84
- Joined
- Sep 28, 2019
- Messages
- 4
- Points
- 1
I’ve got a 2007 fiat punto 1.9 multi jet diesel. I bought it a few months ago (96000 on the clock) and all was fine until a few days in the glow plug light flashed up and I started having trouble starting it from cold. I took it to a garage that changed the timing belt and water pump etc and said they tested the glow plugs and all were working fine, so assuming it must be the glow plug relay I had that changed to a new one last week. The same day, and for a couple of days later, the starting issue got worse (though the glow plug light went off) and I had to jump start it once so today I went and bought a new bigger battery. Now when I start the car it won’t start first time (though does the second time with a very slight rattle noise that I didn’t notice there before) and a warning flashes up on the dash “excess.radiator.fluid.temp TURN OFF ENGINE) which I do then start it the second time and all is fine. Now this happens even after the car has been driven and warmed and the gauge inside the car sits in the middle so isn’t overheating and I always wait a good few seconds before starting the car at anytime, so was wondering if anyone could point me in the right direction on what to check/test/change next please! There also aren’t any coolant etc leaks either.
