This guide is intended to assist you in removing the Door card on a Grand punto which has the Evo Style Door cards ( evo and the new 2012 model)
Anyhow its very similar to the mk1 Grande however fiat have moved some of the fixings and added a couple.......
so first read of the top half of this:
https://www.fiatforum.com/grande-punto-guides/238842-drivers-door-lock-replacement-repair.html
anyhow....
tools needed
pz2 screw driver (pozzi)
T40 Torx driver
5mm Alan key
small slotted screw driver
So first remove the 2 pozzi screws
Then use a small flat screw driver to remove the screw caps from the door handle recess and the door opener lever
Next in the door handle use a T-40 torx driver and remove this machine screw
now grip the handle section and pull it up carefully
and unplug the 2 cable multi plugs
Now remove the 5mm Alan key bolt
then look in the door handle recess you will see 2 more torx bolts
and thats all the fixings out
now you need to pull it up from the bottom corners to release all the press fit clips
once loose shove it upwards as it hooks over the top of the door next to the window
once released lower carefully preferably onto a blanket to avoid scratching the door card
then disconnect the tweeter cable and the door open cable as per the above link
and there you are one door card removed
anyhow....
tools needed
T40 Torx driver
5mm Alan key
