Fiat 2P0697Sensor power supply 3
A quick search
Make:
FIAT
Code:
P0697
Definition:
Sensor Reference Voltage 3 Circuit
Description:
The Powertrain Control Module (PCM) detects a short to voltage or short to ground on the 5-Volt Sensor Supply 3 circuit for 0.6 seconds.
Cause:
5-VOLT SUPPLY CIRCUIT SHORTED TO VOLTAGE
5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
FUEL TANK PRESSURE (FTP) SENSOR
A/C PRESSURE SENSOR
POWERTRAIN CONTROL MODULE (PCM)
It appears the sensors are aranged in groups for distrubution of the ref voltages 5V and 0V
So check earths again and it appears the differential dpf sensor is also in this group.
Help please - I'm a new member (hello all) with a 2013 2.3 fiat ducato motorhome. It has gone into limp mode. So far we (my mechanic) have tried changing the throttle body and pedal, the egr valve, ecu, and have cleaned out the inlet manifold egr pipes and cooler. Can anyone point me in the...
www.fiatforum.com
