Stephen505
- Joined
- Dec 13, 2013
- Messages
- 74
- Points
- 20
Hi Folks,
My first try of the MultiEcuScan / ELM interface was to get a persistant error code: Lambda 1 heater above catalyser. I have the electric warning light on too and through this forum, I have found that it is a linked with the reported fault. I also found that it could be a blown fuse, and would like to replace the fuse before I go to the mechanic (Assuming that the lambda sensor cannot be replaced by a novice).
Cold you kindly tell me where to find the fuse please? I had battery issue problems, and might be the reason of a blown fuse. I was driving the car at 50mpg some 2 weeks ago and now seems to dropped to 42 and below.
