My 2001 1.2 8v Punto is revving so erratically that the MOT tester can't do the emissions test. I've tried cleaning the throttle body & resetting the Self Adaption & the Phonic Wheel using Multiecuscan which seemed the likely solutions but no joy.
Idle is reasonably steady, about 730 to 762 when the target is 750rpm but taking it up to 2000rpm or higher it just goes up & down with no way to keep pace with it using either the throttle pedal or hand control under the bonnet. The MOT emissions test requires a steady high rev (3500 I think?) for a short time which is just not possible at the moment.
Am I missing something obvious? There are no fault codes present. All suggestions appreciated ...
Help
Help
