Technical EOBD fault - ideas please
Floggs100
I have purchased a motorhome about 12 months ago based on a 2008 Fiat Ducato 2.3 diesel engine - it has 32,000 miles on the clock and maybe due for a service - the onboard EOBD light has just come on and id like to understand more - so my questions are - where is the device that monitors this located in a Ducato van - does this need a software upgrade ever as i would doubt if this has ever been done - what would the Fiat warranty cover does anyione know if this is 3 years - is there a way of checking what this means ones-self by checking an error code or something - i would be very greatful if anyone on here knows any answers especially where the device is located in the new Ducato van - cheers in advance - Floggs100
In all vehicles eobd vehicles the connector must be easily accessible from the drivers seat with no tools required. There is a cover under the steering wheel flip out and you'll see the connector. Fiatecuscan has comprehensive cover for a lot of the fiat range the 2.3 should be a bosch 15c7 ecu I think. You can use fiatecuscan with a cheap 'vag-com' cable from ebay.
Many thanks for your help - sorry for the slow reply but been away with work - i got into the diagnostics and it has come up with error code PO481 Cooling Fan 2 circuit malfunction so it is a genuine fault - just need to find out now how expensive and how much work to get done - not sure yet how much this costs so if anyone has an idea let me know
regards
This may be some help
  • Fiat Fan.pdf
My secondary cooling fan is seized solid .. didn't bother fixing it not a problem with our weather! I'd imagine Arkk might need his secondary fan in Aus though! Doh New Zealand can never tell the difference with those tiny flags :p
