Technical  Engine swap
dpr1974
So, because i did a good job with the advice i got from here, my nephew wants me to do another job on his 1.4 stilo.
Will the 1.8 fit in? can the 6 speed box still be used? is the exhaust in the same place? and any advice on this would be welcomed. thank you.
It will physically fit in the engine bay, but you will also need to fit the 1.8 gearbox, clutch, exhaust system, engine mountings, engine management ECU and engine wiring loom. Because of the increased engine weight, you will also need to fit the 1.8 front suspension.
You may also need to fit the 1.8 engine compartment fuse box, radiator, radiator fan and cowlings. There's probably other parts that will need changing, that I can't think of now.
