Engine support for g/box removal
K
Kevin Allen
Haynes manual says engine must be supported via a hoist when removing the g/box to replace the clutch,or the engine will move and cause damage if supported from underneath.Is this correct?
Its correct. You could damage the exhaust manifold, the other engine mounts, all sorts.
Just remember don't put a jack under the sump as you will damage that too.
I
2
1K
Dark Lurker
A
1
11K
Angelo
A
922
David
A
1K
A
