S
Stu
Hi all, just had the engine in the JTD100 2001 replaced as it had had numerous seizures and valves were bent etc etc
Anyway, mechanic has put another JTD100 2001 in the bay which had 48k on (with a 3 month warranty).
Problem is the car fires once and doesnt keep running. It will do this every time you turn the key but wont keep running.
Mechanic had his friend out from fiat who plugged in a diagnostic machine and that said that the top dead centre pick up was faulty so the mechanic replaced it with the one off my old engine (btw 75K). Still no luck. Car turns but only fires once.
The friend from fiat then told the mechanic to check the valve timing again as if they are 1 tooth out they wont start. I have faith in the mechanic so i dont think its that and he says it shouldnt be that because it was spot on!....he's going to check anyway.
Anyway, has anyone had anything like this happen before? i really need to know what this niggle is because ive been without the bravo for 3 months and want her back before christmas!!
All help is seriously appreciated guys!
Stu
Stu
