Technical  Engine pulls back injector light comes on
Multiporter
Hi All,
W reg 1.9 105 JTD, starts first time every time, drives good for a few minutes then engine starts to pull back and falter sharply (doesnt actually cut out) then within a few seconds injector warning light comes on,
Runs well at speeds of 60 to 70 + even with warning light on, the main problem is town speeds or traffic driving then it pulls back the whole time.
I have very recently changed the deisel filter.
If I turn the engine off for a minute or so , then the warning light will go out on restart, but again in a few minutes the pulling back starts and light comes back on.
Any ideas please, your advice is much appreciated.
Thanks Ray:(
When you say injector light - do you mean the red engine block shape light or the yellow coil shape light?
Sounds more like a MAP sensor or fuel flow issue, you need to get the code read to find out what the ECU thinks the problem is.
