engine parts- where from?
P
PeteU
Need to replace all the valves, gaskets, seals, belts and tensioners on my 1.4 bravo, wheres the best place to get bits from? Is there a discount wholesaler/importer?
Or is it a case of going to a fiat dealer?
Pete
urgently need engine parts
anybody?
i've tried emailing ggb engineering, but no reply, almost everything else on the web seems to be dismantlers.
where do you all get your cambelts etc from when changing them?
Re: Re: urgently need engine parts
Who did you email at GGB - their server is fcuked and mail either takes ages in or ages out!
I tlak to them nearly daily so I will give a nudge if you want.
Nige
ggb engineerin
I found their site and catalogue off of the BOO pages, and just used the email on there, [email protected]
i think it was.
I'm after quite a few parts so am interested in getting a few good quotes, before going to fiat and being laughed at!
shopping list!
8 x Inlet valves
4 x Exhaust valves
Cylinder Head Gasket
Inlet Manifold Gasket
Timing Belt
Timing Belt Tensioner
Auxiliary Drive Belt
12 x Valve Stem Oil Seals
Coolant Pump Gasket
rubber oil seals on the Camshaft Lubrication Pipe
camshaft locking tool
crankshaft locking tool
3
7K
Steve
S
M
7K
marko
M
I
2
1K
Dark Lurker
888
David
5
650
Darren
