Technical Engine over-revving / racing
Kiwi Denzil
New Plymouth NZ
I'm sure this is covered somewhere but i'm not much use at navigating around the site....yet.
My 500F engine over-revs / races when it is hot. The throttle and choke linkages are free. It's quite an oily engine and I'm wondering if the engine is consuming excess oil vapours through the intake and causing the over-revving. I had this happen on a landy due to excessive crankcase pressure. Has anyone come across anything similar?
If your dipstick stays in place I doubt you have crankcase overpressure. Maybe the throttle return spring is weak; easy to replace. Also clean and lubricate with engine oil all components of the throttle linkage. Things do expand, and get hung up, when hot.
Ecdy
Folks, all sorted. Did what Bambino suggested and had a look while it was gunning it. throttle not fully against the idle stop. sorted the spring and cleaned and lubed the cable and all sweet again.
Actually I think that was it. New tyres, new brakes, new dizzy cap, rotor and leads and a complete rewire. It certainly feels more responsive - although that could be psychological.
