The management system doesn't like oil thats too tick.
SPD
SPD
Rallycincycming,
I read about how to pre-load hydraulic tappets after I had replaced the head gasket, two weeks ago, I rushed that part of the job because I was working in the street!
So when I first posted the problem you and rallycing suggested I went back and pre-loaded the hydraulic tappets, I stripped it the rocker box off yesterday to do just that.
Incidentally, in a spares box, I have two sets of rocker arms, one from the car originally and one from the scrap yard.
The third set, I had was fitted to the car by a garage in November. When I therefore replaced the head gasket two weeks ago, I had not noticed till yesterday, that the rocker mechanism now fitted to the car, was not the same as the other two sets I had, in that, no nuts are fitted to the push rod end arm for pre-load adjustment!
The other two spare sets therefore, match the description and illustration in the Haynes manual, unlike the third set fitted to the car!
The Rocker mechanism originally fitted have some slight damage on one rocker, where a hydraulic tappet came loose on the way home last November.
The other spare set I got from the scrap yard has no damage to the rocker arms but when I removed it from the car in the scrap yard, not one hydraulic tappet was intact!
The third set with every hydraulic tappet all intact, was put in the car in November by a garage, but this differs as stated as I found out yesterday, not sure why, because all three sets came from Cinquecento's!
Unless the garage butchered them, but i am not sure, as the end that meets the push rod cup is slightly different in shape, perhaps more than one type were fitted, I cannot see a way of adjusting this other type for pre-load, no adjustment seems to be possible!
Can new hydraulic tappets be purchased to be inserted into the rocker mechanism?
By the way I live in Ramsgate Kent.
Cheers for reply
jboy
Thanks all,I mistaken filled one of my 899s with 20/50. It didn't like it, hence the post.
I use 5/50 fully synthetic in my 1108, but thats my choice.
I was only suggesting, that from personal experience of the 899 engine in two different Cinqs, that the recommended oil works better.
SPD
I can't help feeling the whole of this modern motoring experience has become a Corporate rip off, even more than yester-year. Everyone has to buy expensive diagnostic equipment and diagnostic cartridges, otherwise you go out of business, so to re-coup their losses, businesses have to increase standard charges, so like everything else the whole process becomes cash, inflated, in principle a diagnostic could take less than 5 minutes I suppose.
Where's the skill in being a mechanic anymore? Its like a component failure game , the diagnostic tells you the fault code and you replace the part en bloc, oh! and incidentally Main dealers seem to be staffed by people who do not know the first thing about the mechanics of car engines...
So in the future for me I can see it being either Kit car territory, build your own, a Classic car, I can fix myself or if all else fails, a bicycle !
Jboy
