Technical  Engine management problems
Kevink40
United Kingdom
My Fiat 500X diesel 2016 uk model has started giving me engine management faults. Such as the stop start isn't available, and more recently electronic handbrake does not release when driving off. If I turn the engine off and restart it, the handbrake releases. The car always drives perfectly well I bought an OBD2 scanner, but it doesnt show any fault codes. I suspect an earth fault on the ECU. Any other ideas guys. The faulty may disappear again tomorrow, without any interventions.
Model
500X diesel
Year
2016
Mileage
75000
Hello,
A standard (cheap) OBD scanner will connect only to the engine module (ECU). FIAT (as other makes, too) uses a dedicated application, MultiEcuScan (or AlfaOBD) and requires a special interface to connect properly to all modules.
I'd try first finding someone who could properly diagnose the car.
The forum engine will add a hyperlink in my post, which will lead you to the forum register of users willing to help - perhaps someone in your area will be available to have a look.
