Technical Engine Knock
LDF
Melbourne
hello,
I just bought a 1968 Fiat 500F , and it has developed a knock sound like the engine hits the body of the car.
This happens on Start up one or two knocks and also going over bumps
I have. Changed the rear engine mount but hast made a difference. Can someone suggest what else it could be
Lou
Model
500F
Year
1968
Gearbox mount have been recently changed
And coincidentally the knocking became worse after they were changed
When you change the gearbox mounts you have to make sure that when fitted there is as much clearance as possible between the top of the gearbox and the transmission tunnel whilst also making sure that there is clearance between the gearbox cross-member and the bottom of the gearbox---it is a bit of a balancing act, which is why there are slotted holes in the cross-member for the gearbox mounts
