H
hgt_20v
Well now that the 20vt idea is completely out of the picture, I got in this afternoon, and as the bravo had been stood for most of the week decided to do an oil, filter and plugs change as I had spares in the garage.
Took the cover off to do the plugs first and unscrewed the ht lead/block, and out it came with a load of oil!!!!!!
All the other 4 plug holes are fine, just the one nearest to the oil filler cap! So i took off the rocker top (after figuring out how to disassemble the bracket bolted to the side of the rocker cover)and used a syringe and a thin pipe to get all the oil out of the plug well.
Looks like it's been leaking in through the seal on the rocker round the plug hole, so off to fiat tomorrow for a set of 5 and a new rocker gasket.
Question is............
Does anyone know what the correct torque settings are for the rocker cover bolts?
Want to make sure it's right as i've got a trip down to birmingham in a week or two to have the cambelt done, and the last thing I need is a problem on the way down........
Also, does anyone know how tight the cambelt should be between the two pullies that come off the cams at the top? Mine seemed quite slack. Does the hgt have a hydraulic tensioner that only works when the engine is running, or a manual adjustable one?
Cheers in advance.
Cheers in advance.
