Technical  Engine Fault Codes P0203 & P0204
MR GOOSE 1
Hi all
I have 2002 Stilo 1.6 and have been getting P0203 & P0204 with Engine Light on.
Am I right that both are Injector Circuit Open Cylinder 3 & 4 ?
I have had P0202 as well but its mainly 3 & 4
I have read that it could be the ignition coil - if so which one covers Cylinder 3 & 4
Thanks in advance
edited as I thought cylinder instead of coil lol
Goose
First, using a DVOM check the resistance of the injector. If it isn't within specs, then replace the injector. Check for voltage at the fuel injector connector. It should have 10 volts or more. Visually check the connector for damage or broken wires. Visually check the injector for damage. If you have access to an injector tester, activate the injector and see if it operates. If the injector operates, then you likely have either an open in the wiring, or a blocked injector. If you do not have access to a tester, swap the injector with another one and see if the code changes. If the code changes, then change the injector. At the PCM, remove the driver wire from the PCM connector and Ground the wire. (Make sure you have the correct wire. If you're not sure, do not attempt) The injector should activate Replace the injector First, using a DVOM check the resistance of the injector. If it isn't within specs, then replace the injector. Check for voltage at the fuel injector connector. It should have 10 volts or more. Visually check the connector for damage or broken wires. Visually check the injector for damage. If you have access to an injector tester, activate the injector and see if it operates. If the injector operates, then you likely have either an open in the wiring, or a blocked injector. If you do not have access to a tester, swap the injector with another one and see if the code changes. If the code changes, then change the injector. At the PCM, remove the driver wire from the PCM connector and Ground the wire. (Make sure you have the correct wire. If you're not sure, do not attempt) The injector should activate Replace the injector
