starbuster
- Joined
- Jul 7, 2005
- Messages
- 2
- Points
- 1
Uno FIRE engine 1.0 with SPI but NO ignition module?
After 20 minutes of perfect running the engine will die as if the ignition has been switched off. Changing down a gear to rev the engine will keep it going (jerking). If the car stops completely, wait 30-60 seconds, the engine will almost certainly start again! The pattern of the fault is random - damp or dry.
I've checked all connections etc. but as the fault only occurs after engine gets hot and will start a few seconds after, tracing whether its fuel or ignition is proving to be difficult.
Has any one had similar experiences?
Regards
Starbuster
Regards
Starbuster
